View attachment 556119So last weekend I had a injector return hose fail. It was less than two years old and it was one of the cloth sheathed 3mm_1/8" "german" style hoses purchased from a vendor on eBay specifically for that use. So I went on McMaster Carr and went nuts ordering different style hoses. All have an "A" rating for diesel fuel, except for the Yellow Tygon fuel hose which is a "B" rating. I wasn't willing to use the tygon because of the lower reaction rating with diesel and it's low temperature rating. The blue stuff is really soft and very expensive fluorosilicone which is rated for very high temperatures but is way too soft for return hose. The green stuff is kinda expensive Viton, and the yellow stuff is inexpensive Tygon fuel hose. I know a bunch of people have run the Tygon with good results, but this firm Viton stuff seems to be the cat's meow. My pull scale maxes out at 16 pounds force, and even with 16 pounds force the 5/16" OD Viton tube would not pull off the injector nipple. So, if anyone wants to give it a whirl one 5' section will work if you are very thrifty with your hose lengths. Measure twice and cut once to make sure you don't short yourself. The part number is 5119K81.
