Kaiser67M715
- 26
- 18
- NH
Actually, not so bad getting it into the cab corner. You will check the brake fluid level more often when the reservoir is in the cab!just have to decide if I want to try and work myself into the cab corner to mount it, or just mount it on the firewall
Will most certainly try, biggest thing I want to install is a 12 volt plug to run a Dash camera, just ordered a 24V to 12V converter.Post up a video of it running when you are ready to drive if you can.
