- 3,923
- 75
- 48
- Comfort, Texas
The answer to that one is Soldier B and the grandkids.
No kidding; all that product looks like it just came fresh off the factory floor. That is impressive, TWM. Wow.Beautiful workmanship.
Pete
Can I paint the crate???? Please, Please.All those parts look so darn good maybe you should just build a crate and say you have the only known brand new jeep in a crate!!
Yes you may...but you have to use linseed oil.Can I paint the crate???? Please, Please.
I never knew about that detail until you mentioned it here in this thread.Finished the rear axle brake parts install and packed and installed the rear axle wheel bearings and grease seal. Installed the brake drums, washers and nuts and adjusted. Cleaned and primered the rear axles and flanges and will install them tomorrow. Thankfully, this vehicle has most of the original "F" marked parts. Will finish the rear axle tomorrow and begin on the front.
Is that the model:It's a phase detractor used on his nofor trunion during peak usage.
In spite of some tinfoil hat types, that is the central dust collector for my wood working shop with is adjacent to the garage shop. All my woodworking tools are plumbed to this central collector with tube gates with I open and close depending upon which tool I am working with.It cannot be denied, TWM: you always set the golden standard for how it should be done; no kidding.
What's that up on the wall in the back of the shop, is that a vacuum system or something?
