gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 749
- Cincy Ohio
Frank, I think that just gives you access to the lifters and push-rods.
There is no oil seal on the transmission input shaft. So if you invert it you will drain all the oil out. The transmissions uses a reverse thread pattern on the inside of the throw-out bearing flange. As the input shaft spins it flings the oil outward into the reverse pattern grooves and those channel the oil back to the transmission. Jeepsinker was working on a modified flange that would allow for a oil seal like Gringeltaub (Gerhard) made.Ok I'll read up on the booster pump.
I have my EGT and boost gauges now. Drilled and tapped the exhaust manifold. For the boost probe I'm thinking I'll use 1 of the 2 holes on the air intake pipe leftover from the intake flame heater. I placed a large order for parts from 3 diferent vendors TJN Murray, Eastern, and Eriks. Mostly clutch parts and a few other items I needed. Still waiting for my injectors, in the mean time I dropped the Transmission and transfer case. When I drained the Sprag t-case oil I found a lot of metal flakes, note the picture. I'm going to paint the outside of the new Air shift T-case and bolt that sucker in later this week.
The transmission removal was a bit of a pain, I learned of a few ways to make it easier for when I put it back in. I did not remove the PTO. I was eager to see what had caused the clutch to fail, I suspected oil had contaminated it. It turns out I was right, It was saturated with motor oil. The rear main seal is roasted, so I will swap that out. I'm going to check the seal on the transmission by rolling it onto some blocks with the input shaft toward the ground and leave it for over night, if I see any oil drips I'll change that seal out too.
My throw out bearing was toast and the clutch disc was about 70% worn so its a good thing I'm taking care of this.
Question: How much play is normal on the transmission input shaft? mine seems to have a bit of a wobble.
Hey, no pressure . How are you doing anyway ? Arm working OK ?Yes, and I got one done before I got hurt and my machinist got swamped with work again.
I bought my deuce from Murray last month and as little problems reared their ugly heads "they" sent me parts w/o cost. It wasn't a lot of items but a new tranny lid, oil pressure gauge & sending unit among a few other things ain't to shabby. Now, having said that the last text I sent went unanswered but I had figured the problem out anyway so I never followed up. I have never ordered from them but I have a sister an hour away from there, next month I'm going and get what I need off my "wants list". Mostly because it's fun to just walk around and look and besides, they're right behind the casino.Question:
Has anyone had trouble with TJN Murray? I've ordered from Erik's and Eastern they were both fantastic. I have not had the same experience with TJN. They have been stringing me along for over a month now. Wont answer my emails, and when they do its after I've threatened to cancel the order. I've made one final inquiry before I pull the plug. I'm at a road block with the truck until I get my clutch parts from them.
(Edit) the box was shipped today
yahoo!
I've bought many things from them and never had any issues. I had a bit of a wait last summer when I ordered a complete cab seal kit as they were waiting on pieces but they came through.I'm on the up swing now. Heads are on, turbo and manifolds are back on, new rear main seal installed, airshift t-case installed and plumbed, Pyro and boost are partially installed, Fly wheel has been resurfaced, fire wall painted, all the intake parts painted also.
I'll post some pictures up later today
Question:
yahoo!
