TechnoWeenie
1,669
Nova Laboratories, WA
Used 1/4-20 screws through the rear..with a threaded coupler on the outside... and the sign screws in with 1/2 in. 1/4-20. So the signs can be added/removed in 10 seconds. Used the existing nuts on the bottom to secure the convoy sign...
gottaluvit
Fixed my hub that was partially locking itself in. Pretty easy fix. Have no idea why this extra clip was in there floating around, but removed it and gave it a five-mile road test and the hub never moved.20150913_135953.jpg
Also, tore into my nonworking front bumper mounted blackout light hoping to simply replace a bulb. Darn unit is sealed! Anybody got an extra for sale?
cucvrus
10,434
Jonestown Pennsylvania
I may be wrong but I may be right. I think the inner gear is in backwards. With it in that way I think it will only get partial engagement. Please pull it out and look at the gear how it messes completely with the recesss in the gear outward. I am relying on memory from looking at the picture. Correct me if I am wrong. But it is worth a look see. I will go in my basement and look at one while I send this out. Like I said I may be wrong but I may be right. Good old tune and a fail safe way to me as I am always about learning.
gottaluvit
Will look into that tomorrow evening.
86k5
Greenville, ILLINOIS
My starter has been scratch starting again. Tapping the starter with a hammer before starting seems to be helping for smooth starts. Is this an indicator of the starter crapping out?
48cj2a
34
Central, IL
I think he right...
Looks like a recessed area should be on the outside of the inner gear. Look at the inner (left) and outer (right) images of this Warn hub
http://www.venturestruckparts.com/w...LINE-FORD-JEEP-DODGE-CHEVY-271835655558-3.jpg
gottaluvit
cucvrus
10,434
I think he right...
Who He ? Me He? Or He He? And I can not open that link. Is he picture correct? I am am asking because I am not sure myself.
It just seems that the gears are not fully engaged with the recess facing in. But it may be so that the hub can mesh with the gear instantly.
That is why I made the remark that I may be wrong. Still wondering and other people are thanking you for the helpful post. Lost in the mountains of south central PA.
gottaluvit
I think he right...
I think you are both correct. I think I was only looking at the outer. I will pull the snapring tomorrow and check the inner gear. Thank you both for pointing this out for me. At least since getting that extra snap ring out it isn't engaging the hup partially anymore when I drive it, but that gear being in wrong could cause damage whrn I lock them in.
joshuak
214
Slower shore, DE
I made a battery tray and tie downs in order to relocate both batteries to the existing front tray, also gave maintenance to my batteries...
Yep, I'm running different battery sizes 24 and 24f. Not ideal, but its what I had a the moment and they are still cranking. Not fond of wing nuts for permanent applications, right now checking tightness is part of pre trip inspection (it's my DD) and it's getting old. When it's time ($) for my battery cable upgrade, they will go with the battery post clamps that don't convince me either, all in due time.
cucvrus
10,434
001.jpgHung the plow on Voodoo M1009. The lights were broken in an ice storm last year. Time for new ones.002.jpg003.jpgA new radiator is on order for this M1009. It is the OEM one. this is the only vehicle w have that still has the OEM Harrison radiator in it. Time to fly.
gottaluvit
I'm not sure I know what that means, your "County Number"":
- Can you help out an ignorant beggar here, please? :shrugs:
Sorry. Our state (Ohio) puts a sticker on your liscense plate with the county number. Each county has a designated number going in alphabetically order. So my county is #7. Thought it might bring out some pride in my county (even though the roads are horrible!).
Another Ahab
4,556
Alexandria, VA
Oh, I get it; thanks!
You all are one of those states that has all those orderly laid-out counties, whereas over here in Maryland and Virginia our counties all look more like they were laid out by somebody who'd been nipping a little too heavy from that "corn-in-a-bottle".
