Ok folks, I have read through the instructions to remove the fuel tank, and I am still having trouble. I have removed the following so far:
- Top cover
- End cover (fuel tank end)
- Radiator
- Perforated heat shields on either side of radiator
- 4 bolts that hold filler neck to angled plate behind radiator
- Countless other bolts that I probably didn't need to
Per the TM I still need to removed the fuel drain valve, and I still need to remove the electrical and fuel connections from the top of the tank.
But I can't for the life of me figure what is holding the tank itself in.
Any and all help is appreciated.
Thanks,
Mike
