- 6,855
- 680
- Stratford/Connecticut
Those older style Michelins are bad news all around. They are notorious for disentegrating like your picture. They dry rot and you dont always catch it on a quick visual inspection.
I'm not sure who's pucker factor was higher, mine or the young lady in the little Honda that was beside that tire when it let go. Fortunately the gator (tread) stayed in one piece and hung on the axle. The rest looked like it became about the size of ping pong balls. Didn't do any damage to anyone thankfully.Those older style Michelins are bad news all around. They are notorious for disentegrating like your picture. They dry rot and you dont always catch it on a quick visual inspection.
I cannot read the load inflatoon tables. I have looked for these specific ones and never founf them. I think they should be saved I. The TM section because you happened to get very good I formation that is not easily attained. Hopefully the table will show hp on my computer.i can respect the replies and the concern with higher speed, but i would like to turn up the engine and since my 5th gear has already been modified and 70 MPH could be a regular hwy speed for me I just want to do it safely.
I emailed a Goodyear Tech regarding the 395/85R20 G MV/T i had mentioned earlier and here is his reply:
"Peter,
Ah, that takes me back to my old Air Force days at Nellis AFB, working in the civil engineering carpenter shop, driving a deuce-n-half at job sites...
With the 395/85R20 G MV/T, you can go as high as 81 MPH, provided the tires are properly inflated for the tire load. I have attached our engineering data sheets for the two tires. It's important to adhere to the load-inflation table so the tire contact patch is optimal for traction and even wear. You probably aren't loading the tires anywhere near their max load capacity, but you should know that the MV/T tire has a 9370 lb max load rating, vs 9960 lb for the AT-2A. Incidentally, the MV/T is the tire currently used on the FMTV, with which the deuce-n-half is somewhat of an ancestor. Are you currently using inner tubes with the 14.00R20? The MV/T is designed to operate tubeless, with a sealed wheel. If you're looking for new wheels, I can put you in touch with the company who makes aluminum wheels for these types of applications. Likewise if you would want a steel wheel. You'll also want to compare dimensions, looks like the MV/T will lower ground clearance by about an inch. Do you have a source for the tire?
Let me know if you have any questions.
-Dan
Daniel Shy, PMP
Technical Account Manager - Commercial/Military
The Goodyear Tire & Rubber Company
200 Innovation Way, GIC-A 4598, Akron, OH 44316
phone.330.283.3817
daniel_shy@goodyear.com"
He provided some very helpful attachments as well which i'm attaching...View attachment 586214View attachment 586213
I did reply to let him know that this was a 5 ton application, but as you can see in the attachments it shows different capacity with certain psi.
Interesting and useful, THANKS!Peter,
-Dan
Daniel Shy, PMP
phone.330.283.3817
Being I have the M929A2 I might consider turning mine up even though I have zero interest in going over 50 mph. The power increase would make pulling hills with full loads nice. However, my trust in automatic transmissions prevents such action. I will just be patient. The top of that hill will come soon enough. BMY and TACOM made it the way they did for good reason. To be runable when needed.All I can say is don't read the threat titled "So who has bumped the power on a 6CTA cummins" if you are faint at heart or a supporter or slow speed.
Some of the things said regarding speed in that thread would make some on this thread flip out.
Yeah, do a search for ShootinIron on here (RIP) and see what happened to his truck.A rollbar won't improve safety for anyone who isn't in the truck. His life is his to risk as he sees fit...
I found it enlightening to see one that had rolled over...
Even though this happened before my time here and I never knew the man, that thread is never easy to read. I read it every time that it comes up though, always a strong reminder about what could happen if things go wrong.Here you go, this is shocking and sad. We lost a good man http://www.steelsoldiers.com/showthread.php?t=71943
Man your bumper would have opened the top of that car up like a can opener! He was luck you were paying attention.Food for thought: add 10mph to my speed in this unfortunate event and how does it play out?
He would still go by me sideways.... except instead of him narrowly missing my winch with me standing on the brakes, he impacts me solidly and I become a participant instead of an observer. And the odds of him surviving go way down: watching his car come apart as it flipped end for end was bad enough. Imagine what it would be like to squash it with 23,000lbs of steel.
http://www.steelsoldiers.com/showthread.php?145463-Distracted-Driving-Kills
Day before yesterday...
More food for thought of why to avoid the interstate with my MVs. I always find an alternate route.Here you go, this is shocking and sad. We lost a good man http://www.steelsoldiers.com/showthread.php?t=71943
