Hoefler
- 20
- 38
- White Bear Lake,MN
Its a civilian Jeep bought and put into service by the US Army-so I figure its ok to post here. This '77 Jeep was won on GL and came out of Sparta. It served as a fire truck in a presumably dry area. No rust anywhere. Took a bit to get her to run, but unfortunately, the transmission has water in it. The rubber boot on tunnel cover was missing. Guessing that rain ran down shift lever and ruined transmission. Engine is the 232 (smaller version of the venerable 25. Ran terrible which required a carb rebuild and a new HEI distributor.
One thing lead to another which ended up doing a body off fix. I have swapped out the T150 3-speed with a T18 four speed and Dana 20. Replaced the sagging leaf springs and shocks along with bushings and new beefy shackles. Replaced the rear floor due to a big jagged hole cut into original for water pump piping. Sandblasted the underside and prime and painted with Rapco desert tan. Sandblasted the frame and coated with Eastwood ceramic frame paint. Just got the body sitting on frame this weekend.
I plan on painting the rest of the body in desert tan and same color lineX. Will post up more photos as the Jeep more progress is made.
Pete
Pete
