M923: mudding or not?
Easyeight13
PA
So im looking at getting an MV. I would love to take it through its paces (mud/hills, etc) but ive heard that mudding can cause some problems. Any suggestions?
Suprman
696
Stratford/Connecticut
Its not a mud truck. The A1 or A2 with singles are a bit better but when you get 21000lbs of steel stuck in the mud you better have something big to pull you out.
juanprado
2,922
Metairie/La (N'awlins)
High level of maint for mudding/high water.
All those seals, bearings etc and all the gizmos that you need to touch are big and heavy..........
Just a thought but I know those days are past this old man :)
Easyeight13
PA
Yeah, i've heard that water and mud can cause a lot of maintenance issues. Also, yeah you definitely want a winch or something big to pull ya out. Of course, it would be nice if you never got stuck at all, but ive heard that they sink and dig in.
wreckerman893
Possum Connoisseur
15,629
2,054
In the military these vehicles traveled in herds. If one got stuck it's fellow trucks would all get together and pull it out.
They are actually easier to get stuck when empty due to lack of ballast for traction.
My M927A2 has never been stuck because I have never taken it where it could get stuck.
Suprman
696
If you want to move 10 tons of artillery shells down a dry dirt road the truck excels at that. Mud not so much. I have heard from another member he had good luck mudding in his M1078.
Tornadogt
Adkins, Texas
I take my M931a2 with a Deuce bed Mudding pretty regularly. It does well until it starts pushing mud with front axle. all I would change is going to 16x20s and Lockers in the rears... My CTIS does work and I bleed it down to "Emergency" (I think it is 15-20psi) when going through the thick stuff.. I also have a A1 truck but the older engine is much heaver and you can really tell in the mud..
rmgill
14
Decatur, Ga
Mudding is how you break things. Badly. In places you don't want to break them and which make your recovery harder.
On the other hand viewing the truck as able to get through problems without having to go FIND them is the best way to look at them.
kfrosty
Belmont, NC
I've got to believe it's physics. 21,000 lbs in soft mud you're burying. Today, we had a M998 and some steep hills I built on my property for my UTV's. 998 took the hills like a champ. My M932, just too heavy. It sunk sunk some in the soil, tires got gummed up and it wouldn't go up.
Had some more obstacles that have dryed out, as long as the dirt was tacky, hardly anything it wouldn't traverse. As others have stated, regardless, mud/water gets in everything. 4x4's, dirt bikes etc, you run them in mud, you're going to have to spend money maintaining them.
71DeuceAK
416
Fairbanks, Alaska
Yeah, maintenance can get expensive once you have mud/high water involved...but if you're equipped to do that and have a way to get pulled out should you get stuck (A 5 ton is going to be one heavy SOB to get unstuck, mind you) I say go for it; go get filthy regularly once you get one! :driver:
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
There is no other way to find out what your truck can(and can't) do than to wheel it. There is no guarantee you will get un-stuck, but a winch and another truck will do wonders.
aleigh
52
Phoenix, AZ & Seattle, WA
I dunno about heavy mudding a US MV but the word with unimogs is if you bog them bad in mug you have a real chance of ripping out air lines. ironically their 4x4 and lockers are air actuated so you lose both when this happens. that happens with the US rigs too? My 1078 has a looooottttt of dangly things under the frame.
