alltheway82nd
- 0
- 0
- Grand Rapids Michigan
I have recently bought my M1009 it is in N.C....It was bought from an Estate sale...the truck had been registered and upon installing batteries it runs and lot drives. I am currently getting the tags so it can get driven by my brother to see how it does....I am going to fly down and drive it back to Michigan in July...As I am now compiling a list of parts I am going to buy I will put out what I have so far and if anyone has any input as to where or what brand to buy let me know...I plan to keep the vehicle for a Daily driver and it is still in its 24v config..
1.Transmission Filter,fluid and TH 400 oil pan to get a drain plug and added capacity
2.Key/lock set TBD upon inspection if it still military I will
change for security(how can you tell?)
3.Engine oil filter,glow plugs( 60G AC Delco?),spare alternator,harmonic balancer w new bolts,starter bolts,belts goodyear ( p/ns 15491-15551 and 15461)vacuum hoses ,radiator cap,fuel filter(original block type and add an in-line?)fuel pump, air filter, extra fuses, starter relay, wiper blades axle vents
If you think of any thing to add or a good part number or source to use I am looking for your 2 cents as well as searching to forum..I will be shipping some tools to there in advance so as to be able to facilitate the work there..
Thanks in advance for any advice and if you need some thing from N.C. to MI in July let me know and If it will fit I will try to help out...As I am going to get some extra rust free body parts and a rear seat if I have time to bring back..Larry
