L1A1
- 13
- 38
- H'burg, VA
Are the torsion bars in an M548 (or M113 for that matter) identical (interchangable) from first to last? Or does each have a specific position that it has to go (back) into?
Matt
Matt
Sorry Doug, was not even thinking right to left swapping, yes absolutely correct on that count! But as for where they go in order on each side, they can go anywhere agreed?
John
John
Yes, correct.
There is an argument that the more highly loaded bars should go back in the same location
(the ones at the front especially) as they have "bedded in" to that location,
but then there is the counter argument that those should be swapped to the rear to give them a holiday so to speak.
Realistically, I am with you, as long as they are put back on the same side, I expect all should be fine.
The WW2 Germans were highly protective of torsion bars and were VERY concerned about any
scratches or rust pits. Although I have not see any direction markings on their bars, it was
understood that you put them back on the same side.
I don't know about the US, but all the ones I have seen here in Oz have been wrapped with
insulation tape presumably for rust and scrape protection. An Oz M113 crew man told me that
as crew, the one thing they were really careful about was parking the vehicle such that any one
wheel station was not loaded more than the others (eg, on a mound or on a rock or tree branch).
He said that nothing compares to a torsion bar failing around 6am (coldest part of the night) when you are sleeping alongside
the vehicle, he said it sounds like someone fired a shotgun next to your ear.......
The hazard is in buying used bars, you just don't know what they have been up to. eg, knife edge demos - a sure way to abbreviate the life of torsion bars.
In civilian usage, unless the owner is out to destroy his equipment, the average vehicle will see far less use/weight/abuse eg, no slamming into creek
beds, overloaded with kit, rations, ammo and a squad, no high speed jumps etc.
Having said that, I see in another post that one of the US museums has broken 2 torsion bars on an FV-432, I am hoping they reply to my question as to
how they did that.
Regards
Doug
Not with a Museum Doug, just a private collection here in Canada. We do some restorations, build a bit for film projects and spend the rest of the time hunting for parts and vehicles. But with the slide of the Canadian dollar, will probably be keeping acquisitions to a minimum for the next couple of years...but a great time to sell parts and pieces to our neighbors to the south
John
Thanks for the replies and information. Thought it was kind of odd that the torsion bars in my M548 were not wrapped with anything where as the ones in my old M59APC were. Looked like electrical tape to me at the time.
Matt
G'day Doug,John
Yes, correct.
how they did that.
Regards
Doug
Answers in yellow above.Hello
> You'll note that I'm in NZ, not US. The museum I volunteer at is the Museum of Transport and Technology (MOTAT) in Auckland ( www.motat.org.nz ) where I manage the Military Section workshop.
I take it you are still located on that hill a couple of miles from the main MOTAT? Yes. Meola Road aka MOTAT2
Many times as a kid we drove past the Sunderland and Sandringham sitting forlorn after they got marooned by the power lines.
I hope that Sunderland is under cover now? Sandringam is actually a Solent. The last remaining one in the world and is now indoors. The Sunderland is outside still but undercover of shrink-wrap having corrosion removed from inside wings. Fuel tanks are removed.
> So, our 432 is used to give 'Tracked Vehicle Experience' rides to the civilian public
Using an FV-432 for that sort of thing would be high maintenance. I note that Bovvy run the pants off 2x M548 for their rides. Does make you
wonder why they don't use an FV series vehicle...................... Yes. We are used to the high level of running maintenance. It's very labour intensive.
> A lesser-experienced driver was behind the tillers...
In his defence, I would say that over undulating terrain, with civilian passengers on board, and keeping an eye
out for any trespassing children on the course, his vehicle awareness was probably a low priority. Children not able to access running track but protected avian wildlife (Dotterils) are to be avoided at all costs.
> We are aware we drive it hard (But not fast) but have no knowlege of how it was driven when in service prior to arriving in our care.
Assume = flogged. It would be highly unusual for it to have been driven gently. Correct. We do assume 'flogged'.
> Torsion Bars are best bought new so you know their history. We have one Port Side spare and will source another from UK.
I suggest you source more. Won't make make much difference to the price as freight and
import will not be cheap and won't go up much for a couple of more bars. Yes. We have that in mind.
> If you ever come across the ditch do get in touch and pop-in. You're most welcome.
Most appreciated.
Dad's side of the family grew up in Birkedale, (Birkenhead?) they then moved to Brown's Bay (Grandad was mayor of East Coast Bays at one time).
My uncle, in his 80s is still there.
Haven't been back over since 1996. We are looking at another trip over in the next year or 2. Look forward to seeing you.
Regards
Doug
What is your name by the way?Answers in yellow above.
I would add that setting the Torsion Bars for correct ride-height involves use of a gauge. The ends of the bars have differing numbers of off-set splines to enable rotation to set correct pre-load. This is a critical part of replacing T-Bars. You can't just fit them any-old-how.
how they did that.
Regards
Doug
