Fording Project
Another Ahab
4,482
Alexandria, VA
I'm sorry that you got that to deal with.
But yeah, like you said; what you going to do? It's just the way it goes.
You can try complaining, but then everybody leaves, and that's no fun.
:shrugs:
cranetruck
75
Meadows of Dan, Virginia
Thread brings back old memories of a fun project.
Yours truly actually dug his own "fording pit" because there were so few opportunities to test the finished kit.
A couple of images.
2002 0705 0706 adrian, kubota, fording pond (1).jpg2004 0928 fording the deuce 6x6.jpg
Because the brake drums are not pressurized, an "after fording service" will be required, where everything will need to be inspected...a good reason to avoid driving in water more than a foot deep, actually. I learned a lot from that experience.
rustystud
2,813
Woodinville, Washington
A couple of images.
View attachment 607279View attachment 607280
Building your own fording pit, now that is "Hard Core" !!!!
Another Ahab
4,482
Alexandria, VA
A couple of images.
That is one GOOD looking rig you got there, cranetruck.
Do you have a stand-alone thread on here somewhere about it? Because I really need to check it out if you do.
:jumpin:
cranetruck
75
Thanks, yes a very useful combination and there are hundreds, perhaps a thousand posts related to it going back over 15+ years on this forum and some 20 articles in Military Vehicles Magazine related to it, not really a "stand alone" thread on the truck itself, I don't think.
Lots of stuff related to fording, not to get sidetracked here.
rustystud
2,813
Side track by all means ! I would love to see more of this and I'm sure other members would too !
cranetruck
75
Fine, here was my permanent solution to the crankcase breather "problem" when fording. The idea was to make the truck as fording ready as possible.
2004 0422 racor crankvent filter.jpg2006 0312 adapter temp, thermocouple, crankcase ventilation filter.jpg2006 0312 dvm on air intake.jpg
The breather fumes are filtered and returned to the air intake (ignore the DVM, it was part of a non-related experiment) . The "Crankvent" filter has a sump for draining oil at intervals determined by how much the vehicle was used.
cranetruck
75
More fording related details.
2003 1121 6x6 alcohol evaporator installed.jpg2003 0820 6x6 voltage regulator measurements.jpg
Compressor air intake is permanently connected to the engine air filter canister.
A selector valve (not shown) is manually operated to select pressurization of components or not. When not pressurized, components are vented high on the firewall via copper tubing as shown. Regulator cover off for non-related measurements.
cranetruck
75
Measuring your intake temps?
Yes, compared it to temp at intake manifold, where a second thermocouple was installed to show slight intercooler effect (difference was only about ten degrees F). The intake manifold is double walled to help warm intake air when engine coolant is heated by fuel burning coolant heater ("arctic kit).
rustystud
2,813
View attachment 607439View attachment 607440
How did you pressurize your system ? and where did you get that manual valve ? Pictures please !
cranetruck
75
The original pressure regulator looks like this in the TMs.
My truck came from the USMC and had this regulator factory installed.
The control valve is item 28 in the picture and is operated via the "Fording T-handle" on the passenger side of the dash. I'll look for pictures.
