goldneagle
- 1,014
- Slidell, LA
I have a M116A1 trailer I just finished restoring. I am getting a MEP002 5KW diesel generator that I plan to install on it. I am also getting a 55 gallon fuel tank from a M931 tractor. I want to set up the trailer so it will tow properly. How much tongue weight should I have when done properly.
I will be adding some smaller items to the trailer as well. A retractable cord reel, small type 3R circuit breaker panel, some power outlets and ground rod storage. There were 6 Jerry Can holders with the trailer that were mounted 3 per fender. I may put some water cans in them. Also need to install fire extinguishers on the trailer.
Any suggestions as to items to install on the trailer as well as how to lay it out ? Here are some pictures of the trailer after restoration:
