- 3,906
- 3,152
- Peoria, Illinois
Knock because of combusting coolant?Found the problem! See that oil spot on the firewall? Blown headgasket on #6...
-oh, its going to knock real good after idling at that RPM......The idle has always been low (5,000 to 6,000 rpm), but it usually holds a constant idle.
That sounds pretty high to me lol
No, there is no fluid cross contamination. It is just blowing compression out of the back. It probably was making a knocking sound when it first blew and still had some gasket material in there, but once it blew it out it quieted down. It had a barely audible tick, but the way I found it was just that I saw the oil spot on the firewall, then I started it up and stuck my hand back there and felt the compression escaping.
I'll let Mike update you guys with what is going to take place here. We spoke earlier.
Wish I'd sent the Goat over to you. Might have saved me a new engine
Mike - what's the plan for Mullins? I was going to let you drive the Goat but you can't have it all weekend.
Mike, you'll want to get some break in oil for the new engine.
Thanks for the heads-up Mark! I didn't realize that fuzzy has a truck at Jeepsinker's and, as it turns out, a trailer too! I'll tow the M1101 trailer home with me tomorrow. If the timing works, fuzzy and I will pick up our trucks and convoy home next week.Too bad you can't take fuzzy along with you so he could pick up his truck.
Well the body may be broken but the mind is still sharp as a golf ball.Thanks for the heads-up Mark! I didn't realize that fuzzy has a truck at Jeepsinker's and, as it turns out, a trailer too! I'll tow the M1101 trailer home with me tomorrow. If the timing works, fuzzy and I will pick up our trucks and convoy home next week.
