TGP (IL)
- 35
- 28
- Metro East IL
I have searched and read some threads on Gen 2 light but couldn't find
My problem.
Unfortunately a lot of the thread links in a particular thread don't work anymore.
Anyway, last couple of mornings I noticed the Gen 2 light not coming on with the key om
My M1028A2.
However the volt meter read upper green when running.
I have checked with VOM and have 28.4 Volts across both Batteries.
With the engine off, key on I have 24,8Volts at both wire on the two pin Alt. 2 connecter and same voltage
At Alt 2 power stud.
Truck apparently charges fine. Have had no issues with charging other than No Gen 2 light?
Have also cleaned the bulb contacts, but haven't checked the bulb because I thought if the
Bulb was open(burnt out) it wouldn't charge?
Could it be a bad bulb and still Charge?
Thanks
Tom
My problem.
My M1028A2.
Thanks
Tom
