- 290
- 20
- 18
- Odessa/Texas
Alrighty I'm just going learn from this, ill have something to work on for a bit too. I went to Lowes and bought some parts to fix hood, some 6 AWG ring terminals too. A roll of duct tape too I'm going to cover Filler Neck with it, this is only temporary until I pull engine. I need to do it to tighten mounts and it will be easier to pull Filler Neck. I also change oil too,it was very dark for only 8 or so hours and probably sine it was overhauled (think it was 2010). I noticed the engine lifting cable is missing. After checking oil/replaced, air filter, ect. I attached a battery placed it in run to search for any fuel leaks, after that I fired it up. It produces power to lugs, when I replace the filler neck and secure engine mounts ill load test it for a few hours. Going to try auto parts place for filler neck.
