infidel got me
32
Newberry, Florida
Humvee latley
20160421_121615.jpg20160421_121643.jpg20160421_122114.jpg This is the next one were getting from Lake Butler next week or two. The G.P. lot guy Larry pulled it out for us and let us take it for a spin. Ex-Navy Seebees with 2200 miles on the clock. My buddy Dave scored on this one. Hopefully euc will clear next week. I forgot to add our lot guy said that G.P. is instructed to take off the deep fording kits prior to selling to public? Idk if this is true- just wondering if anyone else has heard of this. He said ours kinda slipped through.
86sa
miami fl
Even though it says available for pickup as shown anything can and will be removed at any time. So much for truth in printed word.
EnteJager
NJ
Finally got around to installing the airlift bumper and Rhino carrier.
The rear curtain is installed wrong I know, just makes it easier to take on and off in the nice weather.
Dock Rocker
72
Jackson ms
I don't think I posted this here but I had the cab and bed sprayed with lizard skin. 2 gallons of sound deadener over two gallons of the heat barrier. All I can say is man what a difference. It quietened the interior down to almost normal levels. I highly recommend this if you plan on driving your truck.
160
22
San Antonio, TX
You are correct it is an Australian product there are lots of different versions and distributors on line I just preferred this version. I purchased through Jaycar Electronic or jaycar.com.au and the model is: MP-3354. There are many versions from all types of companies so happy shopping. I going to order a second one for my MUTT.
jake-cutter
13
League City, Texas
Did you hard wire it in?
160
22
San Antonio, TX
I purchased a female cigarette connector that is actually wire into a power supply from dash with a water proof Y connector and male connector that supplies my dome lights. Not worried of over draw because all lights are LED that draws little to no amp/volts. The converter is plugged into that keeping the factor fuse in use. I'm placing a label to state 24V supply. All the plugs are water proof. I also used the original hole on the side wall that holds down the insulation mounting bracket.
Dock Rocker
72
Jackson ms
I finally slowed down and did some wiring for my electronic gadgets. I got my backup camera installed as well as my CB. I also mounted my ram mount for my phone or tablet and ran the wire to plug it into the amp and charge the phone /tablet.
My radio rack was pretty sad looking so I put a coat of textured flat black on it to match the lizard skin.
