FMTV with Shelter, which model?
Suprman
696
Stratford/Connecticut
You will want to seal the roof real well on that shelter they all have water seepage issues and get musty inside. I run a dehumidifier in mine.
Oxyacetylene
179
Stoneville, NC
DanM7890
11
Houston, TX
Weight is just under 1500lbs and it rides fine on the trailer. I could tell the difference when the air was hitting the front vs following a semi.
mkcoen
381
Spring Branch, TX
Good luck with the install. I'm guessing you'll be able to feel it in the truck too. I had a friend put a S250 in a M101 and he said it felt like towing a parachute :)
DanM7890
11
Houston, TX
I know exactly what you mean. When I pulled out from behind the semi to try and slingshot, I lost all momentum. Not much you can do unless you have better aerodynamics on top of the roof to help direct the wind over the shelter once its mounted.
Suprman
696
Cant be any worse than driving a van truck with that thing in the bed. You will want to sand, seal and paint that before dropping it in. And you will want some type of solar powered air circulation.
