Behr Paint Jobs- Show me your MV's
AZK9
PRC, AZ
Nice truck AZK9. Are those 9.00 or 11.00 tires?
If your paint had long enough to set up and isn't bleeding from the rain by now, I doubt that it will. I painted a test area on an M105 and first it rained then snowed and it still hardened up fine.
Hi tobyS...
The tires are 9.00 in size. They're T-Hawks that are in pretty nice condition.
I think you are correct about the 'setting up'. We just finished in time for the paint
to 'shield' itself from the damage that the rain could have caused in the event the storms
had come earlier. We were very lucky! No bleeding and none washed off! :D
USMC 00-08
164
Skiatook, OK
View attachment 602174View attachment 602175
Starting our next MV project! I did have some trouble this time at HD with the code, for some reason they had trouble with the 24087?
But we worked it out!
Is this a picture of the 24087 that HD mixed up? It looks much more green than what they did for me. Could you post up a picture of the paint code they put on top of the can so I can get a sample to try? I like the color of your Jeep!
Gralmk
52
Attleboro, MA
This is what we come up with after several attempts, it's a close match to the 24087!
Good Luck
Gralmk
52
Attleboro, MA
Yea, I feel the pain, we went through maybe 6/8 try's, this was the closest to our match! Hope it works for you!
whistlepig
big branch tn
Another behr paint job made possible by this 002.jpgthread and the paint and bodywork section. Thanks to everyone that has ever contributed info on the subject.
DanM7890
11
Houston, TX
Since this seems to be the main Behr paint page I'll keep it updated. My goal with my truck was to match the doors/top/turn/brake housing color. I went with Desert Tan under the Federal Standard list. Here is the code for a gallon that I used and also the black I used for the grill.
Before & After
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
$10 off behr gallons at home depot thru the 30th. Lets get em painted! Coupons at paint desk
Sent from my SM-G860P using Tapatalk
simp5782
9,339
Mason, TN
28 here in Tennessee. Its an onine submission for the rebate. Still savings
Loco_Hosa
Ethel, Wa
Just picked up a mostly straight M1009 that someone had painted white. There is some surface rust poking through the paint, and IMHO, white on a CUCV seems wrong.
I want to get a flat, durable, military style texture. Desert sand color. Please correct any part of my process that wouldn't help towards that goal. I'm concerned about latex paint and rust as well....
Step 1: Remove wheels and mask off brakes, lights and windows. (What else does the military mask off?)
Step 2: Sand the surface rust off with 80 grit sandpaper, 220 grit for the rest of the truck.
Step 3: Any areas that have been taken to bare metal get hit with “rust converter primer“ (any brand recommendations? How long should I wait to spray the new paint after?)
Step 4: Thin the paint with water since it will be sprayed using harbor freight 47016 gravity feed spray gun, then aply thin coats 4 hours apart.
Step 5: Allow by 30 days for paint to fully harden.
Am I missing anything? I've never painted a vehicle before and I'm a bit nervous. This truck is missing the military bumpers and has chrome instead, can these be painted at the same time?
TechnoWeenie
1,669
Nova Laboratories, WA
You're taking this WAY too seriously.. :D
remove the headlights/tail lights
rub grease on anything you don't want painted.
Paint.
remove grease.
:D
Another Ahab
4,485
Alexandria, VA
I don't think that chrome will take paint (even if you abrade it first with sandpaper no matter what the grit).
Somebody else will have to chime in here, but I think you need to strip the chrome off first.
