WalterMitty
- 0
- 0
- Chicagoland, IL
I have a few questions...I know some might be really dumb, but fully admit to being a mechanical midget.
1) Checking the transmission fluid: Per the manual that I read, you're supposed to do this while the engine is running...it says something like start the engine, put your foot on the brake, put the shifter in each gear for 2 seconds and then check the fluid. If this is right, this is what I did.. I've always check these before with the vehicle not running...so this seemed new/odd to me.
If I did the above check correctly, I'm a little low...just out of the hash marks between full and add.
2) I then parked on level ground and checked the transfer case level, and fluid poured out. Per what I have read, the level should be about 1/2 inch below the fill/check plug. I waited a little bit while some fluid drained out, but it didn't stop right away, so put the plug back in.
3) To repair the vampire issue, I wanted to get some thoughts on which route to go. I feel like there are two main options...
Option 1: Bypass the cooling loop. To do this, I basically create a "U-turn" for the two lines coming from the transmission into the transfer case, so that one line just runs right back into the other. Questions for this option....1) what do I cap off the two holes/nipples that are on the transfer case? 2) Are these two lines that now have a U-turn in connecting them, okay to just dangle? They were connected to the transfer case, now they would just be floating a bit. 3) Is it really okay to run the M998 with this bypass going on?
Option 2: repair or replace the cooling loop. I think there are newer cases, and have improved loops, or I might be able to buy a new loop that can be put into the transfer case. Besides being a lot more money (I have no idea how much more), what are your thoughts on this option? Pros and Cons?
Thanks in advance for the help.
