I have joined the Goat herd
m38inmaine
57
Maine USA
Tom, while I was cleaning out my spare carrier I found a handful of engine cover slats, I think you said you were missing some. A good tig welder could easily replace them.
combat32
106
Booneville AR.
Small update, should have motor back here at my fort Monday, will try to fire it off then. I need to order a new crossover cable from Saturn before I put the motor back in the truck.
m38inmaine
57
Maine USA
While you are waiting for them to arrive try soaking the stuck one in some type of solvent for a couple of days to see if the rack frees up.
m38inmaine
57
Maine USA
Package is on it's way, wish I could make it go faster! Try soaking the stuck one in laquer thinner or acetone and see if the rack will free up, it should just be gummy fuel holding it in place. AMgeneral was able to free his up perhaps you can consult with him.
m38inmaine
57
Maine USA
Tom, I measured 11 3/8 from center of governor pin to center of rack pin, picture is how I measured it. It was my experience that I could not remove or install the rod with the head bolt nearest the governor in place, not enough clearance. Mark in TX may still have his if it did not get launched into the scrap bin or modified for his LMTV. Even with the head bolt removed it was tight, good luck.
combat32
106
Booneville AR.
Good news today, everything is back together on the engine. It will be back at my my fort on the 22nd, we will ground hop it then.
Will try to get some video, hopefully not of pistons flying through the air.
Another Ahab
4,451
Alexandria, VA
I know for sure that you wouldn't be happy with a video like that.
But it WOULD have its own entertainment value for some of the rest of us. :popcorn::mrgreen::naner:
quarkz
Supreme Galactic Cleric
71
Kennewick, WA
Just wondering, did you ever receive a better copy of that disco goat video?
Sent from my Galaxy Nexus using Tapatalk
