Maximum over drive Chevy Tug
4XDesign
47
Blythewood, SOUTH CAROLINA
I hope this is an acceptable location to post the Tug. It was listed for sale and would not go away so I picked it up. It started as a stock tug here are some pictures. I am going to take it to the Georgia rally. Any one that knows me knows I can't leave well enough alone...
image.jpgimage.jpg.
TsgtB
Granbury, Tx
I think we had one up to about 15mph...!!! You should be able to put 90 inch tires on it and get up to 25...
and boy do they BOUNCE.
4XDesign
47
Sharp rig! 6bt? 30mph wfo? Can't wait to see it in action. M101 bed cut down?
It has the original 6.2. You could probably power it using a cordless drill, it has ridiculous gear reduction. It will do 20 mph or so. All of the research claimed the transfer case was in low range and was limited by sheet metal in the floor. So I figured I'll rework the shifter and get two times the speed. The internet lied, the trucks are in high range. I did redo the shifter and it does 10... It's a M105 BlythewoodJoe had I just finished cutting it up.
4XDesign
47
