Modern Russian Army in the photos.
Another Ahab
4,449
Alexandria, VA
The backpack as an ammo carrier makes so much sense, it makes you wonder how nobody thought of that sooner (my squad weapon was the M-60 and we had (2) ammo carriers with me in the squad). The weight of those 7.62mm rounds added up fast though. I was glad enough to carry the M-60 alone (without the belts).
How many rounds are those backpacks rated to carry?
USSR
316
USSR
475
marchplumber
2,718
Peoria, Illinois
Almost 5 belts; that's a lot of one-man firepower.
In 7.62mm I'll bet that's close to 30-35 lbs (14-16 kg). That's a hefty load.
Can be burned through in a very brief time. (Ahab, I'm sure you're very aware of that). Very very heavy till needed. I'll end here, cause it could be construed as not MV related.
USSR
316
USSR
Characteristics
Weight: 4.1 kg without ammunition assembly.
Capacity:
475 rounds of ammunition in the main compartment
75 in the flexible sleeve.
Dimensions:
45*10*30 box,
160*2,5*10 Feed
Another Ahab
4,449
Alexandria, VA
Characteristics
Capacity:
Dimensions:
45*10*30 box,
160*2,5*10 Feed
Are the rounds 7.62mm (or whatever the Russian equivalent is to that)?
USSR
316
USSR
I can't get the video to load for some reason, but are you referring to the vid about the Typhoon-Class sub?
Typhoons in the deep modernization today. This super sub with the eternal body (the body is completely made of titanium)
