dunn001
- 0
- 0
- Massachusetts
anyone know where i can get the tv bracket, just got a m1008 with a bad tranny. any help would be greatly appreciated
82-87 GM square body pickup suburban or blazer with diesel and overdrive (82 was the first year of the 700R4... I think). Not just half tons, they were also used in 3/4 ton applications too.
Getting a a bracket and rod at a junkyard isn't easy picking anymore. Expect to pay $100 or more for one if the seller knows what it is.
Someone on here shut me up on this a while back. Showed a 3/4 burb glove box sticker with the 700R4 OD oprion.Show me a factory 3/4 ton with a 700r4 ?
The 700r4 is only rated for 1/2 ton or less vehicles.
If is true, I'm betting it's a light duty 2wd sub with the semi floating rear axle.Someone on here shut me up on this a while back. Showed a 3/4 burb glove box sticker with the 700R4 OD oprion.
Swing on by & I'll buy.Coffee is on you today.
Yeah, I got a laugh out of that also.It even has the HD Towing package.
In the valley of the engine, drivers side, on top of the intake manifold.Where is this bracket and rod located on these old square bodies?
Ahem........... I have waffled back to the 700R4 again. I'll be keeping my parts.sharecropper may have some parts for you.
