glcaines
- 2,548
- Hiawassee, Georgia
I was convinced that I had a bad starter on my M35A3. The truck had always started very reliably and very quick. The last time I went to start it, the engine turned over about two revolutions and I heard a loud mechanically-sounding thump. The starter wouldn't turn over anymore, but you could hear the starter relay clicking. I turned on the headlights and they were fully bright. I also checked the SG of the electrolyte in the cells and all cells were good in both Interstate 6TL batteries. I always keep a Soneil Model 2404SX1 24V battery minder attached. I pulled all battery cables loose and although they looked very good, I cleaned them. Still no start. I then ran a battery jumper cable directly from the positive side of the batteries directly to the starter solenoid with no result. Due to the good SG and the headlights working brightly, I assumed that the starter had gone. Just to confirm that I still didn't have a battery problem, I used jumper cables attached to each battery separately, connected to the battery in my diesel VW Jetta. No result with the rear battery, but when connected in parallel with the front battery, the truck starts fine. Apparently, the battery is going open internally when under heavy load, but still provides enough power to fully light the headlights. These are the original Interstate 6TL batteries that came in the truck from the military. They are both marked 04/07, so they are both over 9 years old. Not bad performance for the batteries. This is similar experience with the Interstate 6TLs I had in my A2 when picked up. I've heard both good and bad stories concerning Interstate 6TLs, but I'm impressed with the longevity that I've experienced twice. I hate the high price, but I'm probably going with Interstate 6TLs again. It always pays to fully investigate a problem before assuming something is the cause.
