- 12,195
- 320
- 0
- gainesville, ga.
That small draw back is about to change, I have EVERYTHING needed to remedy that small issue except time, so then I WILL have the ONLY m819 with a 5th wheel and a rear winch.
This started out as a draglines fairlead (thank you Ray), everything froze,so rebuild, shimmed, ect., so now everything moves, and tight and welded to the rear outrigger cross beam, the cable will go under the fifth wheel to the rear front winch that will be down in the frame between the crane and fifth wheel,. Just one part of MANY PROJECTS (two many) ALL going at the same time.
