- 2,543
- 2,095
- Efland, NC
Great Ted, Let us know how it turns out.
No I don't. What would I need?Its hard to tell how severe those are. My gut is that they aren't terminal.
Do you have the stuff to do a dye test? To see if there are other micro cracks.
There is a disproportional number of these units with governor problems. Thankfully the majority just need adjustment. Start by follow the procedure in the TM to adjust the pot switches. Do this several times because subsequent adjustments will throw off the earlier ones. If you still can't get the governor adjusted or can't get the unit to shut down, then adjust the magnet. It's a pia to keep adjusting things, but given time you'll get it.I still have major governor problems but that is for another day, probably on troubleshooting.
Diesel Addict... thanks for the prompt reply. Thought about swapping out one from the unit which runs, but not generates... are parts readily available? Can one order a governor?If it goes from stable to unstable with no other changes that is a classic symptom of a failing governor module.
