General Hood
- 2
- 18
- Fort Towson, OK
Hey, good plan. I have a couple of flatfender Jeeps we could use.Actually, I was thinking of a different plan of action
Interesting. But there's still quite a difference in line speed, i.e. the traveling block on my AutoCrane's hoist cuts its lift speed in half, but it's still faster than a truck winch (when it intermittently works). Pulling up a few dozen arches in a minute each, vs. several minutes each, adds up! With my back, I'm not the guy standing 12' up on a scissor lift pulling on a rope hand-over-hand, but as the property owner in this day and age, I don't want to see anyone else doing that, pulled over the edge by a sudden gust of wind pulling back at the wrong second! Which is also a good reason for not dallying when raising a Quonset arch.Thought more about how to use a regular winch with the HMMH last night (that's how I stay sleep deprived) and came to the conclusion that a second snatch block, tied to the pintle hook with a short chain, should do the trick. That way the forces on the crane stay in line with it, and any lateral force will be applied to the pintle hook where it doesn't matter nearly as much.
PTO shaft-drive winches aren't uncommon around here. May I edit your comment? "Wow, they still make those in America?!?" I'll get a PTO after I've completed my Fuller 6-sp tranny conversion (synch, but no OD) w/ Gear Vendors over/under (stock tranny's failing, and increasingly expensive to rebuild/replace). Yeah, the PTO cutouts are the same across trannys, but the fitment's the problem. Meanwhile, I'll happily underpower a winch from my PS. Besides, I hate my E/H crane and want full H from LiftMoore (also in TX, fwiw). A diverter valve can handle running either the crane or the winch, at their full power ratings, top it off with a hydraulic screw-drive air compressor or welder/charger/starter, for a badass little farm truck.That Pierce winch is interesting, as in "Wow, they still make those?!?"
The reason other brands look suspiciously quite similar, is they're Chinese. No thank you! So many identical winches out there, when you get down past all the accoutrements they're supplied with, and the differences in motors, etc. One thing they all brag about, is how well they check their suppliers' products for defects. Well, silly old-fashioned me whose first job was pre-CNC lathe/Bridgeport operator capable of doing his own (simple) setups not just sharpening tools, is sometimes "get 'er right" is more important than "get 'er done." Like for instance, when manufacturing a winch....but for efficiency I think the MileMarker would be better. That one is apparently perfected for running off a measly P/S pump.
Almost! The Pierce is actually "Plan B" because Warn's PS-hydraulic winch (like everyone else's) has a planetary gear. Meaning there's a brake in the middle of the drum. So lowering my windmill, would inherently generate heat, unlike a worm gear. On a practical note, it's the difference between running wire rope vs. synthetic -- synthetic can't stand the heat on those inner wraps, and there are various strategies (splicing thicker/thinner rope, sheathing the first wrap layer) to combat this.And it's hard to go wrong with a Warn.
Crane hoists are worm-gear, so maybe that Pierce can go "vertical" because the admonishment against that, has everything to do with too tight a bend running a wire rope over a roller.Idon'tthinkthatappliestosynthetic,andtheregoesthespacebaragain!Sigh.Still, I understand your concern about relying on a brake, but for repeatedly moving something 80-plus feet, I'd look into a capstan winch.
If you do end up with the Pierce, it should be fairly simple to modify a standard winch mount for the Dodge.
Definitely bugging me yesterday, following a dumptruck from my place with one filament & one LED taillight, why am I having problems? OK, they're solved, so I'll tell ya! Knapheide grounds taillights to chassis, and doesn't offer a harness to plug their service body into either of my Dodge CTDs. I got 'er done anyway, but I had to do two things to the '95 4x4 dually. One -- only one cabover light had a good/existing bulb. My '02 doesn't have cabover lights, so it gets a 10A fuse, the '95 has a 15A. Four bulbs from NAPA gave enough amperage through the circuits in question to make the blinkers work with the parking lights on.View attachment 651779
Pics of the new LED lights. These are H4 housings with hi/low LED bulbs. Half the power and twice the light!
Pardon my ignorance, H4 housings?View attachment 651779
That's special, living in that kind if country with that kind of wildlife around you.Every time we take a break from working up at my place, we look across the small box canyon (and county road) from my homesite, to the aspen grove (with the binoculars, my malamute doesn't need 'em, just a calming "stay with me" now and then 'cuz she really, really wants to go hunting) on the neighboring 7,000 acre ranch on the other side, and see/hear a big, beautiful bull elk with a harem of at least 20 cows moving through the now-leafless trees. All day to set up a 1/4-mile, cold-bore shot, eh? Most every day. At anyone don't belong up here lookin' to poach that fella! Harvest a cow, not a trophy! I've had my property for a year now, the handful of others who belong up here go further away to hunt, and leave this little herd alone. Nice!
Taste test, 10 weight is a bit nutty, HYD is a little sweet.How do I confirm whether or not I have 10 weight or hydraulic oil in the hydraulic tanks?
If you bought it directly, it's a safe bet that it's 10W. If you got it from somewhere else, it's anybody's guess what's in there - well, my guess is that it's 10W which may or may not have had THF added to it, since few of us have 10W laying around.How do I confirm whether or not I have 10 weight or hydraulic oil in the hydraulic tanks?
I think that whether a winch can be used for "vertical" pulls or not depends on how it's mounted. and which kind it is. A Warn 8274, for example, doesn't have anything preventing a vertical pull. Especially if the solenoid box is moved (since there's no law against not using a fairlead, yet anyway). Yes, the mounting wouldn't be as strong as when pulling horizontally as intended, but that would hold true for a Pierce, too.PCrane hoists are worm-gear, so maybe that Pierce can go "vertical" because the admonishment against that, has everything to do with too tight a bend running a wire rope over a roller.
I had a 6 point knocking on my door the other day. Also had a moose drinking from my dogs outdoor water bowl a few days ago. I live at the base of the Uintas at 7500ft in North Eastern Utah.Yeah, it could come in handy some day to be able to club a deer with a 2-foot pipe, or open the sliding door and shoot an elk at 30 yards while laying in bed. Oh, and by the way (so to speak) long sections of Route 66 are undoing themselves.View attachment 651902View attachment 651903View attachment 651904View attachment 651905
Maybe wildlife likes 7,500 feet? That happens to be the elevation where I live, too. And I like it.I live at the base of the Uintas at 7500ft in North Eastern Utah.
The easy way to make LED lighting work on a Ram is to order the VSIM. Aside from allowing LED use, there's wig-wag functions for head and taillights and a whole lot (well over 100) other useful, somewhat useful, and useless (to me) functions available.I didn't ask them about anything but my 2nd-gen CTD Rams, maybe you can get a dongle for a later Ram, I don't know?
