m35a2 air filter swap
m715
western ma.
I want to make space under my hood. Will a fender mount 5 ton air filter swap on to my m35? Does anyone have a pic if this has already been done? I want to install an oil spinner .if I remove the stock filter I will have the room I need. thanks mark.
bigmike
355
Dixon CA.
A fellow SS member "Tracer" has this exact modification on his deuce. He's out of the country right now but his avatar is his truck. Do a search. BTW, I have a take off 5-ton air cleaner housing and brackets if you need them. Has a bit of cancer along the bottom but nothing you can't fix easily or just leave as is.
treva2
ohio
I'm installing a 500HP Cummins in my deuce. I figured I would need a lot of air flow for that HP so I bought a 5 ton air filter housing. It uses 5" in and out duct. I just found a 5" rain cap but for the multifuel it will be easy to adapt the stock rain cap.
m715
western ma.
thanks for the pics,but thats not the filter I was thinking of. I am not sure now where I saw the one I am looking for. I have a m54 wrecker with the lds4651a with the c turbo here I put on my m35 but not what I want.
bigmike
355
Dixon CA.
M715, the one you want is off the 5-ton multi-fuel. Search google for M543A2 wrecker pics. I will respond to your PM after I check to make sure i have all the parts you need.
m715
western ma.
I put my hood and mud flaps back on.I washed the canvass seat cover and am working on a driver seat. I am posting a few pics,not sure what this turbo is.IMG_3691.jpgIMG_3708.jpgIMG_3707.jpgIMG_3706.jpgIMG_3705.jpgIMG_3702.jpgIMG_3701.jpgIMG_3698.jpgIMG_3693.jpgIMG_3709.jpg
bigmike
355
Dixon CA.
I have most of the parts you need for the air cleaner mod. PM sent.
m715
western ma.
Bigmike will you post a pic of what you have here? Thanks for taking time to look for them.I have searched for a pic and still have not found it.the filter I am looking for stands upright instead of laying on its side,best way I can say it.Thanks mark.
bigmike
355
Dixon CA.
Stands upright? Hum, the one I have sits horizontal on the fender. I'm now not sure what you want. It's out on the fender and sits upright?
bigmike
355
Dixon CA.
M35A3 is the one I want on my truck. Can that filter be fitted to my m35a2?
Aha! Now we're getting somewhere. I don't have an m35a3 air cleaner for you. There are several M35A3 owners on this site who can answer your questions.
