- 5,586
- 2,866
- Metairie/La (N'awlins)
Cheap 24v universal pump on ebay $7. Not mission critical. See my build thread for pics and ebay number. Military washer pump crazy priced for a blue water squirt.
What did you use to get that obnoxious soapstone "X" off your hood? I can only get mine to lighten.
This might help you bro.Picture attached of casting number on the engine just in front of the transmission on the driver side. The transmission rebuild plate is visible, and the engine has a similar one on the passenger side under the doghouse.
According to the linked discussion, this means I do not have a Chinese block, correct? Now I would just like to find out if it is in fact a GEP.
I don't want to come across as an expert, because I only know what little I have read, but, yes, it sounds like your engine block is one of the good ones.Picture attached of casting number on the engine just in front of the transmission on the driver side. The transmission rebuild plate is visible, and the engine has a similar one on the passenger side under the doghouse.
From what I'm reading from Videris's link, it looks like it at least confirms that it is a GM or GEP block and not a Chinese one. Now the question is about whether it is a GEP or a GM. Sounds like I need to look at the date code on the other side and for the diamond in the valley under the fuel injectors when I get home.I don't want to come across as an expert, because I only know what little I have read, but, yes, it sounds like your engine block is one of the good ones.
This was sent out by Sintorian last month in another post. Scope it, it might help you out further.From what I'm reading from Videris's link, it looks like it at least confirms that it is a GM or GEP block and not a Chinese one. Now the question is about whether it is a GEP or a GM. Sounds like I need to look at the date code on the other side and for the diamond in the valley under the fuel injectors when I get home.
