Believe me, I've read every forum out and there are plenty of different ways to go about it. Everyone seems to have their opinion of "best" but the best for me looks like a 6.5 turbo set up. Which I picked up for 200 bucks and the turno is good. They are out there, you just have to always be looking. The NV4500 is going to be fresh rebuild so it will be pricy but I want a nice, reliable work horse. I have a couple questions I haventb found anywhere else.
When running the oil return from the turbo and using the small block block off plate, do you just leave the mechanical fuel pump hanging or are all of these guys swapping to electric? I want to keep the mechanical pump. Going to stay away from computers.
I've read about different bellhousing options. Everything I've read, guys grind down the starter nose cone or grinding on the bell housing. Does the Advance Adapters housing clear the 24v DD starter?
I have about half of my parts compiled with the nv4500 in the process of being built. The bell housing is the last piece I might need to order or hunt for. The pedal assembly will be easy to find. Everything else I'll be picking up from the parts store. Anyone that's done this with some insight?
