This thread is gold, the LMTV I just picked up has the same issue, the pedal is not returning to a idle without pulling it up. No problems going into gear thankfully, but it sure wanted to destroy the car in front of it at red lights.
I had a glance at it this morning and didn't see a spring / whatever is causing the pedal to "return". Is it just the throttle linkage / spring on the engine that pushes the pedal through the wire? The pedal does look bent - but I couldn't tell if they are made that way, it does not look "broken", but it is bent about halfway up, sort of perfectly.
What's the consensus on a fix for a stock pedal setup?
