Another Ahab
4,565
Alexandria, VA
The under/inside the hood stencil not used during WWll
In google books it will let you see where that came from.
Me thinks lots of people got hurt. Maybe other posters can say when the hood to cowl latch was incorporated.
I hope nobody got hurt bad, but like lifeboats and the HMS Titanic, those details typically get added only AFTER something goes wrong.
winfred
10
port allen la
yup, like my 109a3 has the top of the radiator smashed down and repaired and a healthy dent in the hood by the safety catch, would like a hood lift kit from BBQROD but he appears to not be around here any more or at least never replied to my PM
assembled the other 3 395/85s for a full set of 6 and cleared a spot in the driveway it can stay till i am done servicing the hubs/brakes/bearings and all wheel seals, verified which front spring seats/caster shims i have are 331-s2's and can be flipped around and shouldn't need to be machined as per what i've read about, got the axle on jack stands but don't have tall enough stands to hit the frame rails, gonna score a couple 12 ton stands from the chinese embassy tomorrow and if it doesn't rain maybe start in on the front axle servicing
Another Ahab
4,565
Alexandria, VA
Would that be Harbor "Fright"?!
chwhite0783
toms river/nj
tires.jpgspeaker.jpgradio.jpgthis week was a busy week. got the g177s installed, and yes adjusted the caster to get rid of the twitchiness.while I was there adjusted the brakes and had to rebuild 2 wheel cylinders. made up a box out of some MDF to put some speakers and a radio in. wired it all up and ready to roll. today off to St Patricks day parade with local Marine Corps League. And then 3 more this month......busy month.
Elijah95
Certified Rookie
1,239
1,197
Georgia
View attachment 669534View attachment 669535View attachment 669536this week was a busy week. got the g177s installed, and yes adjusted the caster to get rid of the twitchiness.while I was there adjusted the brakes and had to rebuild 2 wheel cylinders. made up a box out of some MDF to put some speakers and a radio in. wired it all up and ready to roll. today off to St Patricks day parade with local Marine Corps League. And then 3 more this month......busy month.
Hey we are just about twinning!
DeucesWild11
12
Putnam County, NY
Finally got around to changing my compressor belt.. see pic.. also changed the alt belts which were loose.. Now I got awesome air pressure and my batteries are getting charged correctly.
