wcuhillbilly
- 5
- 18
- Devils Tower, WY
Definatly something to ponder for the upcoming days,,,,, The 816 stock will rotate 270, and by removing the stops 360 but kiss your lights good bye,,, mine are no longer functioning and Im sure its down in the swivel, as I was unloading foundation blocks last fall and everytime we would swing they would flicker and then go out. I cannot find a problem with wires or connection so Im led to believe its in the swivel... Oh well,, that's part of the Headache rack idea....
I love the multi port swivel from DSTI,,, only draw back is that the list says "Get Quote",,, that usually means BOHICA for me.... or nevermind, Ill never be able to afford it....
My rationale for moving the hydro tank was to get rid of that huge filter housing and line supplying the pump, by moving it to the frame rail the filter could be swapped to a spin on and the big supply line could supply the pump, that way the only lines going up into the swivel was the smaller supply and return from the crane valve body.
Davis, Whats the story on the crane swivel for the 936,,,, if the pump is mounted down below, then the tower in the crane turret must be a swivel of some sorts..... I have a picture of it, but didn't have enough time to fully investigate it when I was down there looking at it.
