DFW M923 mechanic needed
WillWagner
2,758
Monrovia, Ca.
Air it up and get out the spray bottle with soapy water. Why pay someone for possibly an easy fix. How slow is the leak?
Fredtexan
Dallas Texas
When I shut the engine off and the pressure in both systems is 110 psi, after 15 minutes one has dropped to 90 psi and the other has dropped to 65.
I have found a few leaks leaks with a soapy spray bottle but am afraid I'd do more damage than good if I tried to fix it (I'm a retired business guy having a blast with my first mechanical adventure).
Also, I was thinking it might make sense to have a relationship with a shop as bigger issues arise.
Thanks...F
Tinstar
1,776
Edmond, Oklahoma
Only way to learn is to dive in.
Read all you can, including old threads.
Good typical set of tools is needed.
Build tool set as you go and as you realize what you need, add to it.
Start small (air leak is a good start) build your experience and confidence as you go.
Do your own oil changes and so on.
Read and follow the TMs. Very important
Tons of info and part numbers.
You will get to know your truck as you go.
Its a big truck with lots of parts, but tackle one thing at a time and don't rush.
I agree with finding a shop, but they will drain your wallet if you use them for everything.
Fredtexan
Dallas Texas
M71mike - great research and I will reach out.
Tinstar - You are spot on about the knowledge in the site, and I'll tackle the air leaks. Still want to find a shop/guy - I dropped over $4k on a transfer case with the best big shop in Dallas - I just need something more reasonable for new issues with "Miss Piggy".
Thank you both...F
Buffalobwana
178
Frisco Texas
I was looking for one too. I think I have a problem to big for me to handle. If I find one I'll let you know. If you find one, please let me know!
There is one in the colony off 121 that I am going to check out. He seems like he is willing to fix anything. Makes me happy and scared at the same time. These machines aren't that difficult once you start tracing lines, and learning what wire, hose, whatever goes wherever and does whichever.
I need a knowledgable guy who has worked on the 8.3 and won't charge $250/hr at the same time.
Anyone else know know someone around here that could help?
Fredtexan
Dallas Texas
And please let me know how he works out.
