911joeblow
- 68
- 28
- Utah
Guys, you may have seen the kits I build for the HMMWVs 6.2, 6.5 and 6.5T which reduces the overall system temps and balances the overall block temps. You will have less fan on time and more power as a result. Longetivity will be improved significantly as well. The side benefit of the kit is reducing the cabin temps as the rear of these blocks runs much hotter than the front.
The issue is that the system will not fit the same due to the difference in the CUCV and the HMMWV coolant crossover pipe. I have developed a different system but I need a guinea pig. So for the first taker the kit will be $200 vs the normal $250. If the kit needs to be reworked you will get the reworked kit. I am 99% sure this will fit correctly but I dont have a CUCV right now to verify.
Below are pics of the HMMWV kits. Several SS members have the kits and they are working great.
