- 7,409
- 2,502
- Interlachen Fl.
Yep then no need to carry any gear oil. As I said he needed to service all bearings and slave cylinders then he is one step ahead axles out when it gets home. I always carried all fluids and to many tools and found it faster to check fluid levels. Think I made Aaron do it. Then I got smart and just stayed home and called Pete with the step deck.Actually, you could pull the spline caps(front) and axles(rear) and it would only roll on the bearings, no need to check that other crap.
