Request M35A2 Retrieval info
texas30cal
87
Brenham Tx.
Also get the bow tie washer, the button falls off bc the plunger is sticky or stuck and fails to follow the camshaft AND bc the clip gets old and fatigued. If the plunger is stuck bad enough it breaks the bowtie washer, will be best to have it on hand, if not broken just put it in there anyway. I think the ambac part numbers are in the sticky thread, I believe it was there that I asked for them.
plunger guide # GU404360
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
The button is on the bottom of the plunger, not the quill shaft.
The quill shaft is what spins the hydraulic head.
gimpyrobb
27,785
749
Cincy Ohio
Just hung up from talking to Derpy. The hyd head is out. The button IS still attached. The drive washe ISN'T broken. I mentioned it might be the delivery valve on the side of the head(12pt screw) but I know those are finicky and hard to get good parts for. I wanted to see what you guys think it could be from here.
He mentioned that some of the injectors had good flow and some barely had any, what would cause that?
gimpyrobb
27,785
749
Cincy Ohio
So he took the 12pt bolt out and looked over the delivery valve, seems in good shape. He DID mention that he could NOT blow through the injector lines from the Hyd head to the injectors.
Anyone have a spare set? I only have one spare line to offer(#4).
texas30cal
87
Brenham Tx.
Good news on the hyd head! Must have been moisture in the fuel that sat in the lines? On steel brake lines that get plugged with rust I use a piece of a old clutch or brake cable chucked in my drill like a roto rooter, BUT idk if that would leave behind trash that could damage the injectors in this case.
Tracer
13,851
Hawthorne, NV.
Don't risk creating more problems, do it right and replace all the lines!
Derpy
alabama
Okay like robb said, i have checked the HH button and all machanics work no problem. but the out take lines are unable to be blown through,AS i spin the gear on the button. If there is a set way to open each valve then please tell me, cuase im buot to soak it in diesl fuel and blow all channels out.
this is my last idea of what is wrong. the symptoms are the injection fuel lines arent constantly pumping fuel as you turn the engine over. then when we bleed the injection line of air, it has pressure behing the fuel for about a whole second then looses all pressure. the engine will start and run for a whole second on eather but will immediately stall afterwards.
rustystud
2,815
Woodinville, Washington
If your lines are blocked due to rust then get some good used lines ! It is not worth the cost and damage you will do to your injectors. Plus now the lines will be weaker then normal and can potentially burst ! You don't want that in your engine compartment ! Or worse yet, getting yourself or someone else sprayed with high pressure diesel fuel ! Look-up what happens if you get injected with high pressure diesel. It is not pretty ! and can possibly kill you. This is something you don't want to play with !
Derpy
alabama
yeah im not sure either, but will take that warning well. also if you say the pressure is that high then it should continue to pumping pressure when i turn the pimps on and NOT lost pressure 1 second in...
rustystud
2,815
OK now I'm confused. I thought you said your injection lines where plugged and rusted ? Now your saying it is in the Hydraulic Head ? If it is the Hydraulic Head then you must completely disassemble it and clean out all those little passages from the "plunger" to the individual injection lines. There are special set screws that hold in special little plugs that can be removed and then allow you to clean the passages, but the plunger must be removed to prevent it from getting damaged.
I added some pictures above showing the set screws and plugs.
Derpy
alabama
i think i found the problem... and man o man is there some gunk in this HH. Ill post a video of it tomorrow, so sweepy.
