Csm Davis
- 393
- 83
- Hattiesburg, Mississippi
Why couldn't you just put the ball valves then the Tee then the regulators? Then you only need the same 2 valves.Not sure if I follow you, but yes you could separate the front and rears, then run a tee from your supply into two regulators and four ball valves. That would actually be nice for airing down just the rears when empty!
Sent from my SM-G930V using Tapatalk
