803 Fuel Gauge
Triton
81
Houston, Texas
This seems obvious to me but I may be wrong. My 803 fuel gauge shows full all the time with power and when the unit is off. It does move at all anytime. To me that seems like a bad gauge. What do you think?
Daybreak
2 Star Admiral
762
Va
Howdy,
Run your unit with a load, and siphon fuel out to see if it moves first.
DieselAddict
1,957
Efland, NC
The gauge is a balanced coil gauge. It will stay where it is when power is removed.
If it doesn't move when the fuel level changes with it running - then you have a problem.
eatont9999
DFW, Texas
Mine does the same thing. Power or not. The tank is not full. I swapped in a known working gauge from another unit and it pegged the opposite direction past empty even though there is about 1/3 tank of fuel in it. Triton, does that accurately describe the issue you are having?
Triton
81
Houston, Texas
My needle never moves off of full, power or not, I have kept the tank full so I'm going to drain some out today. I just did the well nut and cleaned the tank so I know the float is't stuck.
csheath
198
FL
Check your ground on your sending unit.
This and also on the gauge. On mine I discovered the ground was daisy chained from one gauge to the next. A loose or dirty ground at one gauge strap could cause multiple gauge malfunctions.
Care also has to be taken not to over tighten the nut on the power post. Doing so can cause it to ground internally. Mine also had this problem and I was able to turn the base nut counter clockwise just a fraction to cure it.
Triton
81
Houston, Texas
Drained some fuel out today and the gauge still didn't move, checked the ground and it seems good. Took all the wires off the gauge and it still pegged on full, can I disassemble the gauge to see if it is stuck or is it sealed?
Guyfang
23,349
Burgkunstadt, Germany
What about opening the -24 manual and looking at the test procedures?
Fuel Level IndicatorInspection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 2-67Installation...... . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-68Removal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .6-67Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-67
And here is for the sender.
Fuel Level SenderInspection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-104Installation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-104Removal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-104Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-104
dav5
182
Mono, Ontario
My gauge was giving erratic readings. I removed the sender cleaned all the connections reinstalled it and it pegged below empty. A new sending unit fixed the problem.
Triton
81
Houston, Texas
I went through the test procedures and it looks like my gauge is bad. I was thinking of the Stewart Warner gauge because of the 2 years warranty, Does anybody here on SS sell the original Beede gauge?
TheAlfredo
11
Miami, FL
I was able to buy one last week for $15 (NOS). I hope it works, but he seller would refund if it doesn't.
If it doesn't work I'll buy the Stewart Warner "Heavy Duty Plus". Looks identical except the gas picture is green. You will have to buy their 24 to 12 volt converter that goes on the back
Triton
81
Houston, Texas
So where do you find an NOS gauge for that price? I search for stuff on the net and can't find much unless it's a military supplier and the are ridiculously priced! I never see anything on fleabay except whole units
dav5
182
Mono, Ontario
The best way to find parts on Ebay is to follow Guyfang's advice and search using the NSN. They are often on the site but not listed by the generator name.
eatont9999
DFW, Texas
Part of the reason for that is when guys like me buy a triwall of misc parts, we don't always know what each is specifically for. Usually we only have the NSN number and a vague description of what it is, like "fuel gauge." I have a ton of military vehicle parts that go to vehicles I have never seen listed for civilian sale.
