Tinstar
1,933
Edmond, Oklahoma
You can make a new fuel feed hose with 3/8" fuel hose and some split loom. It will be a bit longer but it will work fine. I made a few. I have done a few updates with a new metal line. A few look like the engine was pulled while the fuel line was still hooked up. Bent the metal line up and then kinked it. They just hammered it down. I removed the line and made a shorter metal line with a barbed/beaded edge fitting like the original one. If you want see pictures let me know. But I would remove the old line. Check it closely. Cut the ends of the hose off where the clamps were and reinstall with fresh clamps. Good Luck. But if the pumps wet. You may as well change that.
Already have a new Delphi fuel pump on the way just in case.
Filter was just changed when I installed new injectors. Their dry.
Good tip on that weird hose.
Will do that for sure.
Hopefully it’s just the fuel pump and my IP didn’t crap out.
Will troubleshoot when I get back.
HATE being gone and can’t work on it!!!!
cucvrus
10,467
Jonestown Pennsylvania
View attachment 707681Put LED work light where the ginormous turn signal goes. Will re-lamp the little blackouts for turn signals.
Think real hard before you do the B/O light hole as a turn indicator. From a safety point of view. Can people see that small light blinking? NO. Can it cause and accident? Yes. Why? Why risk life and limb? I tried it once. I went and got a grille from a quad headlamp system and that was the answer. That hole is too small for a park / 003 (3).jpg004 (2).jpg004 (3).jpg006 (2).jpgturn indicator. At night the headlamps over power the small LED amber light. This is an opinion. Do as you wish. I would save the ticket or the accident and put something on that is visible. You still need to come up with a front park lamps also. Good Luck. Better yet go with the LED headlamps. Have a great day.
Recovry4x4
LLM/Member 785
1,821
GA Mountains
You could sub a better light for the blackout and probably be successful. I have some smaller Whelen lights that are pretty bright and may fit the hole.
olly hondro
545
tucson AZ
short range comms
FRS.jpgOne for me, one for the spotter. Charades-type hand signals do not communicate anything useful to me, I prefer to hear words.
olly hondro
545
tucson AZ
studying the wiring diagrams
I recall a famous line from 3 Stooges episode (A Plumbing We Will Go), Curly grabs a length of electrical conduit thinking its a water line : "No wonder it doesn't work, it's plugged up with wires, nyuk, nyuk". As I repurpose the GND bus to a +12 V bus, I encounter various plugs/sockets that do not connect to anything. I am removing any wiring that serves no purpose for my trail-rig application, starting with the diagnostic port. "Oooooooh, a wiiiiise guy":)
DREDnot
445
Phoenix, AZ
Gear tray/jerry can mount...
Recovery equipment in a 1989 german insulated food can. No rattles.
Cell phone pocket
LED magnetic dome light.
