MarcusOReallyus
- 816
- Virginia
Fancy t-stats are an invitation to trouble.
It sounds like your cap is working since it had pressure behind it. That just leaves a crack somewhere. Either the heads or block. You might luck out and find the water pump is bad.Well drove the truck this morning, still not getting up to temperature as it should. Just checked it tonight, recovery tank was slap full and had bin pushing coolant out. Upper radiator hose was hard as a rock, and when I removed the radiator cap it released a burst of air. I have one more thing I can think of to try as mentioned earlier, and that's check to see if the water pump is moving coolant. Tomorrow I'll pull the upper radiator hose and see if what I get. ... I'm open to any idea's.
Why is your upper radiator hose rock hard, but you're not up to operating temperature? This seems to indicate that your thermostat is stuck open. Additionally, your radiator cap might not be venting @16PSI (or whatever the stock rad cap is spec'd for) and could be holding too much pressure, which is what's emptying the radiator and flooding the recovery tank.Well drove the truck this morning, still not getting up to temperature as it should. Just checked it tonight, recovery tank was slap full and had bin pushing coolant out. Upper radiator hose was hard as a rock, and when I removed the radiator cap it released a burst of air.
The Felpro instruction are posted in post #6 . Reusing head gaskets will just make you better at when you redo it cause they didn't seal .Felpro head gaskets have sealing bead, and are supposed to be installed dry. Besides new gasket, you should use new head bolts, as these are 'torque to
yield',
