Possible air compressor failure M925A2
Russ Knight
1,054
Perry, FL
I think my compressor has failed. My low air alarm activated last night as I was pulling into my driveway. I walked around the vehicle and could not hear any air leaks. Any suggestions of things to troubleshoot? If the compressor is bad, where is the best place to get a 2 stage unit to replace it?
CARMAN
86
Broad Run VA
Not to stick a fork in it but on mine you can hear the air compressor cycle on and off. Its clear as day when mine is running and pumping air.
Russ Knight
1,054
Perry, FL
If it turns out to be the compressor, I want to replace it with a two stage one. Anyone have the correct part number and best place to source one?
simp5782
Feo, Fuerte y Formal
9,385
Mason, TN
Your standard ss296 compressor turns out up to 13.2cu ft of air at 120psi. A very good husky 2 stage only does 14cfm at 90psi. You should not need more air. If you do. Add 10 to 15gal more of tanks and upgrade the main air lines to 3/4". Especially upgrade the glad hand feed lines to 1/2" or 3/4" as they are just 1/4" orginally
Sent from my SM-G935P using Tapatalk
tobyS
833
IN
You seem to be jumping the gun on compressor when the unloader in the head of the compressor is probably stuck. Loosen the tube on the top of the compressor and see if it will build pressure. After you take the unloader tube lose at the top of the compressor, get some air tool oil (Marvel Mystery Oil) in it (it takes a very small funnel) and follow that line to the control on the firewall, then take the control apart, clean and lube it (I use red grease which is near waterproof). Do the easy stuff first, you may be surprised.
Russ Knight
1,054
Perry, FL
And after further investigation, I’m thinking it shouldn’t. I think the air pressure comes the other direction and that is what controls the unloader which is what cycles the compressor on and off?
tobyS
833
IN
Sounds like a stuck unloader valve in the head of the pump. It unloads with pressure, so no pressure should make the pump, pump. Some oil may help free it up. It's a pain in the butt to get off to take apart and clean. If you take the output manifold lose you can confirm if the pump is pumping.
With the tube off the pump, use shop air and blow in the other end of that tube and make sure it is open. Watch to see if it blows water and debris.
sandcobra164
301
Leesburg, GA
I agree tobyS. I called myself doing some preventative maintenance to my truck by oiling the head of the compressor with PB Blaster through the unloader line. A few drives later and I had the dreaded no air pressure issue. Turns out whatever gunk was available was loosened by the solvent, migrated to the unloader and stuck it. I had to take the head off, clean everything up and it's been fine since. Mine may be different as I'm 250 powered and haven't messed with an A2 variant in many years. Concept of operations is the same though.
Russ Knight
1,054
Perry, FL
I removed the line from the unloader and squirted some aerokroil in it. I'll let it sit overnight and see what happens. That back bolt on the unloader looks treacherous.
sandcobra164
301
Leesburg, GA
I hope it works but I'm worried you'll be in the same boat soon. Mine was working fine until I sprayed some solvent in the unloader line. After taking the head off and cleaning everything, I feel certain I will be fine for years to come. I was amazed by how much carbon junk was inside the compressor on my truck.
Russ Knight
1,054
Perry, FL
Where did you get a gasket set?
