DCIV
- 0
- 0
- Morristown, TN
Well I did only have 20psi in the tires as that’s what the manual said. Maybe more pressure would help. I really think they are just old tires, I have not torn apart my hubs but did change the fluid in them.Exactly. I was going to type that too.
Check your tire pressure. Unless you’ve got other problems, I can’t think of a reason why it would be bouncy at 35mph. You can fill to 30psi or so if you’re not off-road a lot. The manual is 22-20, but that’s off road.
Have you opened up your geared hubs for rehab? Strongly recommended.
Bulldogger
What do you think I have a bad hub?
