BenRoberts
Certified insane
- 1,367
- 208
- 63
- southwest/ohio
It's not nice to talk about your date like that395 XZL with runflat is around 420. 16.00 with run flat on wheel is 587 lbs. Nothing to it.
Yea. That's one reason Robert put a crane on his 925 so the big girls can get in the back!It's not nice to talk about your date like that
I told you not to tellYea. That's one reason Robert put a crane on his 925 so the big girls can get in the back!
Sent from my SM-G935P using Tapatalk
Are y'all trying to tell us: "What happens in the back of a 5-Ton stays in the back of a 5-Ton?"I told you not to tell
Well Robert is riding on those 14.00 Goodyear AT2s so shes bound to bounce out if he hits a good enough bump.Are y'all trying to tell us: "What happens in the back of a 5-Ton stays in the back of a 5-Ton?"
Hmmmm..... God's watching you!
Nope, no abnormal working conditions. I thought I had it fixed after replacing the injectors, so much for that idea. Now I need to figure out where to get new parts without breaking the bank. I still can’t believe that Cummins wants $422 just for the upper gasket set on this motor.Wow that's awful... was it running under any unusual conditions?
Only 15k/725hrs if the gauges and engine are original. Temps have only gotten to 16 at the lowest so far so I doubt that temps are the culprit. No idea about factory or reman on the motor. All I know is that Jeff (CSM Davis) said it was a Red River Rebuild when I stopped by his place to get the cargo bed.What kind of miles and hours are on this truck? what are the temperatures low/very cold in your area? and was this a factory or remanufactured engine?
Thank you,
John
