74M35A2
- 330
- 83
- Livonia, MI
I planned to drill on the lathe then tap with the mill. Would love to tap on the lathe as well,but no way to have the tap feed in at its own rate on the lathe because the tailstock just has a crank wheel on its end to extend it vs the mill has a pull down spindle depth lever which can let the tap advance at its own pace.
Want the retention plates removable for servicability if joints need to be changed again, something in their area serviced, don't want weld heat on already sensitive rubber. When doing it to new rod end inserts which are not yet installed, and have freeshop tools at disposal, then why not?
