shawnshumvee
Janesville WI
Done some research on my engine today and with the help from Member's on this site and my personal digging I have came to the following conclusion on my engine.
Its a 6.5 GEP Optimizer with casting numbers:
Rear upper portion of the block casting numbers: Left side-12555506 & Right side-12-5-M= 2005. (December 5th 2005)
506 found in the intake valley.
Double triangles (<> the navistar casting mark) also found in the valley of the intake.
J28 found on lower driver side of the block.
So given the new engine data (Year) and my odometer is very clean (really clean) and only reads 19k maybe, JUST MAYBE it was replaced and is accurate? The Milage and the engine that is. I know Military odometer readings are often unreliable but hey, there is a chance? Moreover, all over my engine is colored company markings (QC markings) which is a very good indication that the engine isn't to old or at least it hasn't been ran very much because these makings are found on newer clean engines and don't last to long engines with age and higher milage. I mean i even have markings on and near exhaust components which definitely don't stay on for long.
take a look at the pictures and let me know what you think.
Bulldogger
651
Quantico VA
Minor but been meaning to get to it
I slit 4 twelve inch lengths of 3/8” diameter tubing and slipped them over the door crossbars so the vinyl windows won’t get as scratched when I tuck them in. Window open weather is coming!
Bulldogger
suzukovich
141
Gibsonton Fl
We after dealing with the gremlins in my powered steering. This weekend provide vehicle support for the Suncoast Chapter 14 of the Korean War Veteran Association at England Brothers Park in Pinellas Park on Saturday. Then today was in the Greek Independence Day Parade in Tarpon Springs Fl. And of course Biff Burger Millitary Vehicle and Motorcycle show also on Saturday.
Sent from my SM-J727U using Tapatalk
NormB
70
Cloverly,MD
Bulldogger
View attachment 722435View attachment 722436
As they say (whoever "they" are - well, THEY know who they are), it's the little things that matter most.
I'm sure your HMMWV appreciates the gesture.
Actually, all sarcasm aside, that's a great idea.
Thanks again for posting.
Bulldogger
651
Quantico VA
Thank-you for noticing. I wish I could have gotten a lot more done, but yes, little things count too!
Bulldogger
Bulldogger
651
Quantico VA
Added some dynomat sound deadener. Going to make a center console out of wood or fiberglass.
Did you have a lot of challenges in following the corrugations? Any tips for those of us afraid to try?
Bulldogger
FFesco
New York
Bulldogger
None whatsoever, I would recommend buying the good stuff, Dynamat, conforms very easily. I did use a handheld torch to help “fuse” it once I was finished.
FFesco
New York
How noticeable was the sound reduction?
Sent from my SM-N950U using Tapatalk
It’s definitely noticeable, more so when I put it on the back side of the doghouse! I plan on putting down a piece of plywood on top of it as well as a center console that will also be insulated. Definitely recommend the Dynamat!
infidel got me
34
Newberry, Florida
Replaced the non-grease able lower ball joints yesterday. My Humvee sounded like a pirate ship creaking over bumps. Not a bad job at all- took about 3 hours and I took my time. Truck is happy again....:D
Bulldogger
651
Quantico VA
Did you take any pictures along the way? I’ve a few non-greasable ball joints too I might replace. Looks like an involved job!
Bulldogger
infidel got me
34
Newberry, Florida
Sorry no pics. but it's not bad. They bolt in to control arm. Remove wheel and use a jackstand. Lower balljoint nut is 15/16-- ball joint bolts are 9/16. Air powered pickle fork to separate joint from steering knuckle. The lower bolts are a little tricky to hold, I used a 9/16 s-wrench
Action
1,556
East Tennessee
The lower bolts come out easy if you remove the hub first. Did you rip the boots with the pickle fork?
