74M35A2
318
Livonia, MI
Why do you guys run that much battery? Is it just the “more is better” thing going on? Does your alternator suck? Run a lot of loads with the engine off? Engine hard to start? Going hybrid?
I just see a lot of un-necessary cost and weight, but maybe there is something I don’t get. Don’t take it the wrong way. I do like to see people replacing batteries with new, as it greatly frees up the alternator for other tasks and should never need a battery charger after doing so.
TechnoWeenie
1,669
Nova Laboratories, WA
8Ds are less battery than stock...
Stock is 4 6TL..
6TL =
CCA @ 0F = 825 CCA
CA @ 32 F = 1010 CA
215 Mins RC @ 25 Amps
and they're in series/parallel so 24V instead of 12V and 2020 CA and 1650 CCA and 430 RC
8D =
1720 CA and 1400 CCA and 430 RC
So, you actually have less CA/CCA going 8D....
The NHC250 needs all the help it can get during cold starts.
I don't have a problem with 2 group 65's though, personally...
big block 88
17
Topeka/Kansas
I would say the main reason is winter. Going from 4 of the 6tl to 2 of the 8d we gain cranking amps but loose reserve.( these 6tl's were the 625 cca). On a bad winter day and with no block heater away from any power source, i want to spin those 855 cubes as fast as i can to get her to light off.
The 923 has a lot of accessories like ac, cb, blietooth for phones a stereo, and aux lighting. Aswell as an inverter so juice is good
Jbulach
2,136
Sunman Indiana
More is always better!!! More horse power, more gears, more amps... unless you drop something and cause a short, then more is BAD!
74M35A2
318
Livonia, MI
Understood, thanks, I need to think outside my block more, answer is to start the 250 engine, especially cold. Guess I'm spoiled, 8.3L with a modern gear reduction starter nearly fires-off with an Eveready 9V.
74M35A2
318
Livonia, MI
Their failure is rare. They are built very robust, and their duty cyle usage rate is very low. If you are not using it to prime your fuel system, they will last darn near forever, if not submerged.
Buffalobwana
177
Frisco Texas
I replaced the fuel hose on three of mine with braided steel hoses. Best upgrade I ever did. One sat for 9 months and didn’t loose a drop of prime. Fired off in an instant.
TechnoWeenie
1,669
My air leak was the ether fuel pressure sensor.... The diaphragm leaked..... I replaced the lines from the tank to the spin on fuel filters I added, and most of the way to the IP.....
Let it sit for 6 months, and in the cold, it cranked over after a couple revolutions.... No issues since...
MKD73
Eudora, Kansas
Is there a cross reference part number for the gear reduction 11 tooth starter? I need to replace my starter and I am getting wore out just carrying the old one around.
Thanks!!
US6x4
2,188
Wenatchee, WA
After 4 days of hand stitching I got my back window zipper sewn back in place. It took 2 passes with a single needle saddle stitch and lots of industrial strength thread. It was actually somewhat therapeutic. Maybe I should join up with the quiltin' grannies down at the stitch-n-bitch...
What I started with.
I also got a third seat belt installed for the kiddos.
And I finally cleaned off the anthrax looking junk on the stack that the previous two owners ignored.
74M35A2
318
Livonia, MI
There is no part number, I custom build them from modern conventional components to fit each application. 24v is somewhat rare in US except for a few buses and most all off-road applications, so I don’t always have stock.
airmech3839
Augusta, GA
Hey guys I'm trying to help a non ss buddy out who is working on a m925a2. I'm looking to get him the TMs but the links for the m920 series are dead... anyone got them and mind sharing?
