sandcobra164
- 301
- 83
- Leesburg, GA
Eli,
Picture looks good. Not sure if you towed it just like that but if you did I need to give you a wag of the finger. I don't see safety chains. Basically you need to have chains that run from the front axle of your deuce to the rear shackles of your 5 ton in the event a towbar pin fails. It rarely happens but in the event it does, you need to maintain control of your towed load. I have towed many trucks and have never broken a pin but it helps provide peace of mind.
Joseph
Joseph
