Hey guys are the in tank fuel pumps still available for the m 135 series of trucks ? My frame mounted electric is putting out too much pressure and causing flooding issues . Thanks
My bad. I thought it was the same as my M211 engine.The 302 military engine had no provision for a fuel pump. It is in the tank. I believe it runs 3-4 psi. I run inline pumps now without issues. I run 6-8 just because that is what the gauge in my regulator says. It may not be very accurate. Get the iinline regulature with a gauge that reads in the 3-4 psi range. Some don't go that low.
I have a "REO Diamond" . So it is suppose to have the GM 303 engine ?It should be. What engine is in your truck?
Yep , a GM 302 is the correct motor for your truck .I have a "REO Diamond" . So it is suppose to have the GM 303 engine ?
I'm not sure now. I was pretty sure it was a "Diamond" though. I had the truck scrapped this spring. The engine had two rods through the side of the block so I didn't try to save it. I sold the axles and let the rest go.Yep , a GM 302 is the correct motor for your truck .
Are you sure it is a REO motor and not a International "Red Diamond". REO had the Gold Comet motor they used.
